IOS Licence: 3750 Switch
Jun 22nd, 2009
I have purchased the cisco 3750 switch from cisco retailter that comes with the IP base image. I want to upgrade it to IP services image to have more functionality. Does it require to purchase the licence? I have the CCO account and can download the Ip services image from cisco website but i am not sure its legal or not? your help will be appriciated.
Collin Clark Mon, 06/22/2009 - 07:48
  • Purple, 4500 points or more
You do need to purchase the Enhanced Multilayer Software Image license to legally run it. If you can provide the exact model (post a show version), we can get you the part number to order.
Hope that helps.
t4tauseef33 Tue, 06/23/2009 - 05:41
Can you please tell me for which IOS versions i have to pay the licence?
Switch-01#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(25)SEE4, REL EASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 16-Jul-07 03:24 by myl
Image text-base: 0x00003000, data-base: 0x01040000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR E (fc)
Switch-01 uptime is 1 year, 9 weeks, 6 days, 1 hour, 55 minutes
System restarted at 12:30:49 GMT Tue Apr 15 2008
System image file is "flash:c3750-ipbasek9-mz.122-25.SEE4/c3750-ipbasek9-mz.122- 25.SEE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-48PS (PowerPC405) processor (revision C0) with 118784K/12280K by tes of memory.
Processor board ID FOC1003Z35J
Last reset from power-on
5 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:C8:0B:18:00
Motherboard assembly number : 73-9365-08
Power supply part number : 341-0108-02
Motherboard serial number : FOC10023FCN
Power supply serial number : DCA10010148
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3750G-48PS-S
System serial number : FOC1003Z35J
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT09532DH4
Top Assembly Part Number : 800-25408-02
Top Assembly Revision Number : B0
Version ID : V02
CLEI Code Number : CNMWN00ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750G-48PS 12.2(25)SEE4 C3750-IPBASEK9-M
Configuration register is 0xF
Collin Clark Tue, 06/23/2009 - 05:48
The part number is CD-3750G-48EMI=
Note that your SMARTNet Maintenance will change. Below are the options and part numbers (part #'s are in parenthesis).
SMARTNET 24X7X2 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-S2P-3750GPE) 24x7x2
ONSITE 24X7X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-OSP-3750GPE) 24x7x4
ONSITE 8X5X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-OSE-3750GPE) 8x5x4
SMARTNET 24X7X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-SNTP-3750GPE) 24x7x4
SMARTNET 8X5X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-SNTE-3750GPE) 8x5x4
ONSITE 8X5XNBD Cat 3750 48 10/100/1000T PoE + 4 SF (CON-OS-3750GPE) NBD AR
SMARTNET 8X5XNBD Cat 3750 48 10/100/1000T PoE + 4 SF (CON-SNT-3750GPE) NBD AR
