Blocking outgoing Caller ID
Jun 22nd, 2009
Is there a way within CallManager 7.0 to block the outgoing caller ID on a particular group of phones while the display information will still get sent on all other phones?
Jaime Valencia Mon, 06/22/2009 - 09:42
  • Cisco Employee,
  • Hall of Fame,
    2011
Configure a separate route pattern for those phones and send another mask (maybe main number) or restrict the calling number.
Simply add the new partition to the CSS of the phones you want to restrict CLID.
java
if this helps, please rate
Kenneth Mohammed Mon, 06/22/2009 - 09:42
  • Silver, 250 points or more
Is this MGCP or H323? Either way this is most possible.
Kenneth Mohammed Mon, 06/22/2009 - 09:50
OK....basically just follow the advice that java posted above and you should be good to go.
