06-22-2009 09:29 AM - edited 03-04-2019 05:12 AM
I have a question on BGP. I have a router speaking BGP to multiple neighbors. It is generating a default route using 'default-originate' command to all of its neighbors. I would like to have some neighbors stop receiving this default route. How can I filter this default route on a particular neighbor.
06-22-2009 09:42 AM
use neighbor x.x.x.x default-originate instead under router bgp.
06-22-2009 10:05 AM
The task I would like to do is to remove the all 0.0.0.0 entries learned from BGP on this particular router:
Router A#sh ip bgp
BGP table version is 14, local router ID is 2.2.2.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* 0.0.0.0 5.5.5.1 0 6533 6511 6511 i
*> 5.5.5.1 0 0 6511 6511 i
r 1.1.1.0/24 5.5.5.1 0 6533 6511 i
r> 5.5.5.1 0 0 6511 i
r 1.1.2.0/24 5.5.5.1 0 6533 6511 i
*> 2.2.1.0/24 0.0.0.0 0 32768 i
*> 2.2.2.0/24 0.0.0.0 0 32768 i
*> 10.10.1.0/24 5.5.5.3 0 0 6533 i
* 5.5.5.3 0 6511 6533 i
*> 10.10.2.0/24 5.5.5.3 0 0 6533 i
r 30.30.2.0/24 5.5.5.1 0 6533 6511 i
r> 5.5.5.1 156160 0 6511 i
*> 70.70.70.0/24 5.5.5.3 25753600 0 6533 i
*> 222.222.222.0 5.5.5.3 0 0 6533 i
Router A#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 5.5.5.1 to network 0.0.0.0
200.200.200.0/30 is subnetted, 1 subnets
C 200.200.200.0 is directly connected, Serial0/0/1:0
B 222.222.222.0/24 [100/0] via 5.5.5.3, 00:05:57
C 211.211.211.0/24 is directly connected, GigabitEthernet0/1
1.0.0.0/24 is subnetted, 2 subnets
D 1.1.1.0 [90/156160] via 211.211.211.1, 03:37:37, GigabitEthernet0/1
D 1.1.2.0 [90/156160] via 211.211.211.1, 03:37:37, GigabitEthernet0/1
D EX 222.222.100.0/24
[170/30720] via 211.211.211.4, 01:49:46, GigabitEthernet0/1
2.0.0.0/24 is subnetted, 2 subnets
C 2.2.1.0 is directly connected, Loopback0
C 2.2.2.0 is directly connected, Loopback1
100.0.0.0/30 is subnetted, 1 subnets
C 100.100.100.0 is directly connected, Serial0/0/0:0
70.0.0.0/24 is subnetted, 1 subnets
B 70.70.70.0 [100/25753600] via 5.5.5.3, 00:05:59
80.0.0.0/24 is subnetted, 2 subnets
D 80.80.1.0 [90/156160] via 211.211.211.4, 03:37:40, GigabitEthernet0/1
D 80.80.2.0 [90/156160] via 211.211.211.4, 03:37:40, GigabitEthernet0/1
5.0.0.0/24 is subnetted, 1 subnets
C 5.5.5.0 is directly connected, GigabitEthernet0/0
111.0.0.0/30 is subnetted, 1 subnets
D 111.111.111.0
[90/2181120] via 211.211.211.3, 03:36:22, GigabitEthernet0/1
[90/2181120] via 211.211.211.1, 03:36:22, GigabitEthernet0/1
10.0.0.0/24 is subnetted, 2 subnets
B 10.10.1.0 [100/0] via 5.5.5.3, 00:05:59
B 10.10.2.0 [100/0] via 5.5.5.3, 00:05:59
30.0.0.0/24 is subnetted, 2 subnets
D 30.30.1.0 [90/156160] via 211.211.211.3, 03:36:24, GigabitEthernet0/1
D 30.30.2.0 [90/156160] via 211.211.211.3, 03:36:24, GigabitEthernet0/1
B* 0.0.0.0/0 [100/0] via 5.5.5.1, 00:06:00
Alameda#
06-22-2009 10:51 AM
create a filter list:
Something like this should work.
router bgp ASN
neighbor x.x.x.x route-map IN in
ip prefix-list IN seq 5 deny 0.0.0.0/0
route-map IN permit 10
match ip address prefix-list IN
06-22-2009 11:25 AM
Hello Rick,
good idea I would refine it in this way:
ip prefix-list def_route seq 5 permit 0.0.0.0/0
route-map IN deny 10
match ip address prefix-list def_route
route-map IN permit 20
to allow all other prefixes learned from the neighbor without the second clause all prefixes are denied.
Hope to help
Giuseppe
06-22-2009 12:15 PM
Your solution is great. It works for me.
I was running into the problem that you described. Without the second clause on the route-map, all prefixes will be denied.
Thank you all.
