**************1751 Boot Error Message******************
Jun 22nd, 2009
Hi Pros,
When upgrade the IOS via Rommon, the unit has taken the completed image;However, when I issue the boot command, I got the following message below"
Machine check vector
PC=0X81450D34 , vector=0x200, SP=0x800063dc
monitor:command 'boot' aborted due to exception.
Can someone give me an ideas what does that mean? Is it a physical issue with the board?
Thank,
Crazy
Yudong Wu Mon, 06/22/2009 - 14:29
  • Gold, 750 points or more
It could be a bad hardware or corrupted image. Since you got this issue after you upgrade IOS, I would suggest you to download the IOS image from CCO and do the upgrade again.
