3560 with two ISP
Jun 22nd, 2009
all,
I have a small shop. we are thinking of add another internet service here. Our current one is no longer trusted. My question is Can I use a 3560 with IPS image to connect the two ISP. Can i run load balance on the 3560 switch
Joseph W. Doherty Mon, 06/22/2009 - 10:19
It depends. Believe at L3, 3560 supports most "standard" routing features, includes those that support multi-path routing, but there's often more involved when moving from one ISP to multiple ISPs. So, a 3560 may, or may not, be suitable in your instance.
thotsaphon Mon, 06/22/2009 - 10:37
  • Gold, 750 points or more
Obi,
IP services image? Are you connecting 2 routers/ISPs with cisco 3560 switch? The easy way is to add 2 default routes on it. Then you do NAT on the routers.
C3560 can't do NAT. Does it still meet your requirements? If so,you can use it.
HTH,
Toshi
ougwuoke Wed, 06/24/2009 - 08:10
The ISPs are Ethernet handoff. My plan was to connect them both to the 3560 switch and create a small network between the switch and my ASA firewall.
thotsaphon Wed, 06/24/2009 - 08:16
Obi,
Like I mentioned, Cisco 3560 switch can't do NAT. So you can use ASA to do so. ASA can't do PBR. You may think of creating 2 interfaces or subinterfaces on ASA to separate 2 ISPs then do 2 default routes.
HTH,
Toshi
