Cat 2960G can do IP routing?
Answered Question
Jun 22nd, 2009
Folks, I see some information on the Cisco website that 2948G switches can do Layer 3 functions.
Then I attempted to use the Cisco IOS configuration tool in order to find images for Cat 2948G and Cat 2960G, and I see no ip routing image listed for such platforms.
So my question is, can a Cat 2960G do ip routing after all?
I thought that was available only on Cat 3550/60, 3750's and beyound but I want to confirm.
Correct Answer by Edison Ortiz about 7 years 11 months ago
2948G was a special hardware release and it can't be compared with any of the current 2900 series switches.
For more information on the 2948G, please check its documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2948gand4908g/12.0_18_w5_22a/configuration/guide/config.html
BTW, this device is EOL for a while now.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
thotsaphon Mon, 06/22/2009 - 10:17
  • Gold, 750 points or more
Cisco 2960 switch can't do "ip routing". it's a Layer2 switch.
HTH,
Toshi
Joseph W. Doherty Mon, 06/22/2009 - 10:23
"So my question is, can a Cat 2960G do ip routing after all? "
No.
" I see some information on the Cisco website that 2948G switches can do Layer 3 functions."
Correct, in that the switch "understands" IP packets for some features. E.g. "Advanced QoS".
[edit]
Correction: misread 1st statement's 2948G to as also a 2960G. It's the 2960G that "understands" IP packets for QoS. Edison has great reference for 2948G's L3 features.
Correct Answer
Edison Ortiz Mon, 06/22/2009 - 10:32
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
news2010a Mon, 06/22/2009 - 10:54
That explains then. It was as special case. Thank you very much.
