VRF Route leaking to Global RIB
Jun 22nd, 2009
Hi All,
As per attached network diagram I have setup the VRF Cust_A between 6509-VLAN-RT
and the 2811-Cust-RT routers, which works as expected.
I am trying to inject global route into VRF and vice versa but I was only
successful to do so by adding a static default gateway 0.0.0.0/0 on the VRF with next hop pointing to the 6509-DMZ-RT and static route for the VRF VLAN pointing to the vlan interface.
By doing the above I am able to communicate between VRF VLAN and other Non-VRF VLAN's on the 6509-VLAN-RTR, but I am unable to communicate to VRF VLAN from 6509-DMZ-RT, in other words unable to communicate from outside of the 6509-VLAN-RT. Please check the attached config and advise what is happening wrong with my config.
Amolak
