Unity 5 - external calls getting NU tone
Jun 22nd, 2009
I have an issue where external calls to an IP Phone are failing when that tries to route to voicemail.
Internally - calls route fine and voicemail works. Externally - calls come into the system on an E1 - get forwarded on busy or no answer to Unity and the end caller gets an NU tone. In Call viewer in Unity - you can see the call hitting the system twice in quick succession with a duration of 0 or 1 second.
Here is a Q931 debug:
Jun 22 14:32:05.416: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x5FB8
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98385
Exclusive, Channel 5
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band inf o
Calling Party Number i = 0x1083, '4477165403999'
Plan:Unknown, Type:International
Called Party Number i = 0x81, '2997'
Plan:ISDN, Type:Unknown
Jun 22 14:32:05.444: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xD FB8
Jun 22 14:32:05.616: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0xDF B8
Progress Ind i = 0x8188 - In-band info or appropriate now available
Jun 22 14:32:06.308: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x DFB8
Cause i = 0x80AF - Resource unavailable, unspecified
Any ideas? I've looked at DSP resources, alternate extensions, rebooting the voice gateway, rebooting Unity, etc......!!
The gateway is a 2821. The IOS is 12.4-15T8 advipservices.
Jaime Valencia Mon, 06/22/2009 - 13:03
MGCP or H323??
That error is usually because codec issues, what codec is Unity configured for and what codec the dial-peers or location?
if this helps, please rate
davidme Mon, 06/22/2009 - 13:22
H323 gateway.
Dial peers are set to use G711u as preference 1. Unity is also set to use that as are the regions.
Jaime Valencia Mon, 06/22/2009 - 13:36
Any errors in unity's App Log for those calls??
I've seen this before when using UCM 5.1 and Unity Connection 2.0. The fix was as follows:
Choose Service > Service Parameters and click CallManager.
Scroll down to Disable Alerting Progress Indicator and set this parameter to True.
Full details at this link:
This fixed my problem on UCM 5 but I now have the same problem with UCM 7 and Unity Connection 7 - unfortunately my previous fix hasn't cured it this time.
