ACS database replication and Active directory integration
Answered Question
Jun 22nd, 2009
Hi all
I have to configure Two ACS SE with Internal Database replication.Also I have one active directory server which need to integrate with ACS.My doubt is I need to configure IP address of both the ACS during the installation of Remote agent on active directory or only the primary ACS
Correct Answer by Jagdeep Gambhir about 7 years 10 months ago
No need to give IP address of both ACS. Give IP of Primary ACS.
~JG
Do rate helpful posts
Overall Rating: 5 (2 ratings)
Correct Answer
Jagdeep Gambhir Tue, 06/23/2009 - 07:15
  • Red, 2250 points or more
~JG
anva12345 Wed, 06/24/2009 - 07:24
Thanks JG
for this information.But what happend if Primary ACS fails?
Jagdeep Gambhir Wed, 06/24/2009 - 14:25
That does not matter RA will still work for other appliance. Remote agent could have only one host config provider, but can serve 5
appliance.
~JG
