06-22-2009 01:05 PM - edited 03-06-2019 06:23 AM
I am a little confused with how to use the ip default-network command to configure a default route. Can someone explain the difference using "ip default-network" and "ip route"?
Thanks.
06-22-2009 07:21 PM
Hi Francisco,
You would use ip default-network when your device is configured with no ip routing. It really means device doesn't need to perform any kind of routing (like a PC) and use the IP address as its default router/gateway.
When you are using ip route, ip routing must be configured. ip route means you want to set up a static route for certain destination.
HTH,
jerry
06-23-2009 06:12 AM
Correction...
It should be ip default-gateway.
jerry
06-23-2009 06:27 AM
More correction,
ip default-network is used to select a network as a candidate route for 0.0.0.0/0.
ip route is static route entry that will go into the routing table.
To explain this in an example:
ip route 172.16.0.0 255.255.0.0 172.16.1.1
ip default-network 172.16.0.0
when a packet destinated to 172.16.0.0/16 network, router will route it to 172.16.1.1, at the same time, when a packet destinated to network has no specific match in the routing table (0.0.0.0/0), router will use the 0.0.0.0/0 and send it to 172.16.0.0 network.
jerry
06-23-2009 06:18 AM
Hello Francisco,
some protocols support the ip default-network concept:
instead of simply specifying a default gateway or advertising a default route 0.0.0.0/0, the protocol can send out an advertisement for the IP subnet of the default network with a special flag that says that it can be used as exit point to outside world.
The protocols that support ip default-network are RIP, IGRP and EIGRP.
To be noted that the ip default-network have to reference a different major network (class A,B, C) then the one used internally.
Also EIGRP and IGRP require a network command for the ip subnet for being able to send the IP route with the external flag.
Hope to help
Giuseppe
