Enabling Http on a 3560 switch
Jun 22nd, 2009
I have a couple of 3560 switches and I had Http enabled (LAN), now for some reason i cannot get to them from inside the network using the internal IP address. Can someone give me the command to do that?
thotsaphon Mon, 06/22/2009 - 20:46
  • Gold, 750 points or more
James,
Please post the configuration regarding your question. Let's check things as follows:
1."no ip http access-class xxx"
#you can modify it based on your security policies.
2."ip http server"
3."ip http authentication local"
4."username optimusprime privi 15 password megatron"
HTH,
Toshi
davy.timmermans Tue, 06/23/2009 - 02:57
  • Silver, 250 points or more
and you're able to ping the IP address of the switch?
