ASA5520 - IP Using Old Translation
Jun 22nd, 2009
hey all, we originally had a one-to-one static translation from private to public IP. the translation has been removed and the private is supposed to be using the global nat pool. but, for some reason, it is still using the public ip originally mapped to it. we checked show xlate, and the translation is not there. it was verified with a sniffer and indeed it is still using the public ip. any workaround or other way of verifying this besides rebooting the box or doing a global clear xlate? thanks in advance, robert.
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Mon, 06/22/2009 - 17:39
  • Green, 3000 points or more
Hi robert,
Did you do clear xlate after deleting the static nat?
one quick way to clear it without affecting xlate table do clear local-host
show local-host shows its current connections
clear local-host should clear all embrionic connections
regards
ho.robert Mon, 06/22/2009 - 17:54
show local host x.x.x.x doesnt show anything. we will try and clear it out anyways. thanks for your help!
JORGE RODRIGUEZ Mon, 06/22/2009 - 22:57
np.. let us know what was the fix, reboot will never tell us why - reboot as last resort, Im sure clear xlate without rebooting should do the trick.
