WAAS and TACACS
We are trying to get our WAAS environment to authenticate against TACACS and then fall over to local if TACACS is unavailable. For engineer logins everything is working as expected. However we are seeing several thousand failures against the TACACS server from a username of "CMS". This user is not configured in the CM or in TACACS. So we log the failed login and CMS logs into the WAE due to the failover to local mechanism. Looking at packet captures, and debugging aaa on the WAE's it is definitely a CMS user that logs in but shows 127.0.0.1 as its "from" host. I am fairly confident this is automation within the WAE syncing with the CM or vice versa. Does anyone know how to get WAAS and TACACS to work together without a mass amount of login failures? Is there a way this CMS user can be cloned/duplicated on the tacacs server? What is the password for this automation user?
Thanks in advance.
