WRP400 AT modem commands
Jun 22nd, 2009
I m trying to set up a WRP400 with at HUAWEI E220 MODEM. the problem is that I need to set up modem commands like +cgdcont=1,"ip","basic.m2m"
To initiate the fixed IP adress. But is there any way to do this with the WRP400 modem.
Best regards Terje Gilje-Sørnes
energimesteren Thu, 06/25/2009 - 02:28
Another Question.
How to save this AT command instead in the HUAWEI E220 modem instead. Should the command be like this AT+W (writing to flash) Then I can set up the modem in a laptop before I use it in the WRP400
Best Regards
