Lobby Ambassador Managment of Users that have expired.
Jun 23rd, 2009
Hi there all :)
When you set users up on LA and you set a user to a "controller list", the entry on the listing always shows the account as active from the front menu even if the time has expired.
You then go into the account and you can see the date has expired, and if you test the account, yes, you cant login.
Is this a bug?
I am running WCS version 4.2.62.11.
Also, I would like a function on LA to allow me to delete all expired users in one go. Is this possible?
As the above indicates that the users is not expired but active, at the moment, you have to go into every account, check the expiry date and then delete the account one by one.
Painful?
Many thx indeed,
Ken
Rob Huffman Wed, 06/24/2009 - 05:09
Hey Ken,
Is it time for a beer yet??
In answer to your first question, I think you are seeing this bug;
CSCsk17497 Bug Details
D3WCS:lobby ambassador-guest user account expiry not shown clearly
Symptom:
After successful scheduling the Guest account, the detail page for the created account doesn't show the expiry time details.
Conditions:
This condition arrives only when the browsed account is the scheduled account.
Workaround:
The detail page has the 'start' and 'end' time selection, which can be used for the expiry detail.
Further Problem Description:
Status
Fixed
Severity
3 - moderate
Last Modified
Any Time
Product
Cisco Wireless Control System
Technology
1st Found-In
4.2(47.0)
Fixed-In
5.0(28.0)
Hope this helps bud!
Rob
kfarrington Wed, 06/24/2009 - 05:23
Hi Rob,
Always time for beer mate. yum yum :)
I think here it looks like they are talking about scheduled accounts? Would that be correct?
I just do a normal "add user" and on the front summary page where it shows all users it does not show me status expired but shows status active.
Also, are they saying that the workaround is that you can configure the summary screen to add fields onto it, to show the start and end date on the summary screen?
Sorry if I mis-understand?
You had a beer yet?
Many thx
Ken
Rob Huffman Wed, 06/24/2009 - 05:29
Hey Ken,
It's just after 7:00 AM here, so still a tad early for a "cool one" :) I think you may be quite right here, that this bug doesn't quite fit. My bad! I'll keep digging.
Here's to a virtual one later!
Cheers!
Rob
kfarrington Wed, 06/24/2009 - 05:43
Hey mate, many thx indeed,
BTW. never to early. Go on, grab a bud.
I am searching the bug toolkit also :) will let you know if I find anything dude!
Ken
tuominenj Wed, 10/28/2009 - 02:01
Hi there,
I have the same problem with WCS 5.2.130. After account (created as "Add User", not scheduled) is expired, it stays in the user list as "Active" and you cannot add the same username until you have manually deleted it. This is a problem if you are creating accounts based on guest's name.
Did someone find a solution for this?
Cheers,
Jussi
Trending Topics - Security & Network
