uneble to configure cisco ip phone 7960 series
Jun 23rd, 2009
Please I am unable to configure cisco ip phone 7960 series, I need to desactivate DHCP, but I can't
I don't see the option to unlock keyboard
How can I do ?
Iwould also like to know if cisco ip phone 7960 series can work with asterisk ?
Brandon Buffin Tue, 06/23/2009 - 06:06
Press **# once you're in the Settings > Network Configuration menu to unlock. Yes, the 7960 will work with Asterisk.
Hope this helps.
Dennis Mink Thu, 06/25/2009 - 20:34
you running a Skinny firmware on the phone?
if so, flash it to the SIP firmware.
plenty of forums that tell you exactly how to do that
nicanor00 Thu, 06/25/2009 - 23:19
I d'ont really understand what is skinny firmware. But I am unnable to change network parameters of the phone
When I disabled DHCP and save , it don't accept
please helps
david-lima Fri, 06/26/2009 - 12:20
Hi friend, first disable DHCP (DHCP Enabled=NO) then change the IP address, mask, default gateway, ip tftp server and then press save.
The phone will reset to load your new configuration.
All the best
