DNS Servers for CUCM 6.1
Jun 23rd, 2009
The addresses of our Network DNS Servers are changing so I need to change the addresses configured for lookup in CUCM (v6.1.2).
Can someone please remind me whereabouts I need to change these?
It's been so long since they were set I can't remember!!
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 06/23/2009 - 05:18
Hi Lee,
Yes, you can change the entry after installation
by using the following CLI command:
CLI > set network dns
Enter the IP address of the DNS server that
you want to specify as the primary DNS
server. Enter the IP address in dotted
decimal format as ddd.ddd.ddd.ddd.
Consider this field mandatory if DNS is set
to yes (DNS enabled).
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/6_1_1/install/cmins611-cm.pdf
Hope this helps!
Rob
