port errors in cisco switch
Jun 23rd, 2009
HI,
I have cisco 2950 and cisco 2900.Had a trunk between both the switches.The problem is i got lots of input errors in the connected switch in only one port.Both are set to speed 100 and duplex full.The errors often seen wwhile configuring speed auto and duplex auto in both the switch port connected trunk ports.
why we see lots of input errors in switch ports even if speed and duplex setting are same???
shiva
Giuseppe Larosa Wed, 06/24/2009 - 00:07
  • Hall of Fame,
    Founding Member
Hello Shiva,
may you post a
sh int type x/y
to see what type of errors appear.
You say:
>>" The errors often seen wwhile configuring speed auto and duplex auto in both the switch port connected trunk ports. "
I can guess you had auto and you have moved to fixed config.
Be aware that cabling can play a role here. A bad patch cable can cause problems.
Hope to help
Giuseppe
Leo Laohoo Wed, 06/24/2009 - 14:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Shiva,
In addition to Giuseppe's post, the WS-C2900 series switches is not really well known for auto-negotiation particularly speed and duplex.
I'd recommend that you reboot the WS-C2900-XL-EN and see if this has made any improvements. Use the command "show controller ethernet " to find out what specific input/output errors you are getting.
Hope this helps.
