Unified Messaging
Jun 23rd, 2009
we are implementing unified messaging at my company. We ran into an issue with 7960 ip phones for some reason it will not work with UM. Is there a different configuration for users that have multiple lines?
After installing a Cisco Unified IP Phone into your network and adding it to Cisco Unified CallManager, the phone should start up as described in the below URL:
When you connect a Cisco Unified IP Phone into the network port, the phone should go through its normal startup process and the phone screen should display information. If the phone does not go through the startup process, the cause may be faulty cables, bad connections, network outages, lack of power, and so on. Or, the phone may not be functional.
