How to Access Wireless Router by GUI
Jun 23rd, 2009
After following configration i am trying to access the router by GUI. But i am not able to. kindly advice.
Interface Name Port Vlan Id IP Address Type Ap Mgr Gu
est
ap-manager 1 30 172.30.30.250 Static Yes No
management 1 30 172.30.30.20 Static No No
virtual N/A N/A 172.25.25.1 Static No N
Thanks in Advance,
Milind Tare
Stephen Rodriguez Wed, 06/24/2009 - 08:19
not enough information. What type of device are you trying to access? NM module in ISR, 210x? what does the config of the connected port look like?
If this is truly a "wireless router" i.e. NM Module in an ISR, issue the following commands:
config wlan disable 1
config interface vlan ap-mananger 0
config interface vlan management 0
Then try to access the device again
