Site to Site CME-Transfers
Jun 23rd, 2009
I have two CME 7.1 sites connected via T1 and using h323 dialpeers to route calls between them. I am using g711 codec between sites (as I need to get to CUE and I have no transcoding resources). I have noticed that, if I do a transfer between phones in one site, I get to do a consultative transfer (I can hit transfer, wait until the call is answered, announce the caller, and then hit transfer again). However, if I try to transfer to a phone on the other CME system, I get only blind transfer (I hit transfer, dial the number, and the transfer button goes away). Can someone point me in the right direction for getting transfers working between sites? Thank you.
Nicholas Matthews Tue, 06/23/2009 - 17:12
  • Red, 2250 points or more
telephony-service
transfer-system [full-consult] [full-blind]
This can also be under the ephone configuration, so you may want to check there. Also, check the ephone-dn you're testing, and see if it is single or dual line.
If it is single line, you should recreate the DN and make it dual line.
Ex:
ephone dn 1
number 1000
or
ephone dn 1 dual-line
number 1000
-nick
paolo bevilacqua Wed, 06/24/2009 - 03:05
  • Hall of Fame,
    Founding Member
Thing is, the OP mentioned that supervised works locally, so these setting should be already in place.
Likely the issue is something else.
