06-23-2009 06:21 AM - edited 03-15-2019 06:40 PM
How do we offload CDR flat files from Callmanager 6.x.
Mudassir
06-23-2009 07:03 AM
Configure a billing server
java
if this helps, please rate
06-23-2009 07:28 AM
My situation is we dont have a bill server right now, its under planning.
But I dont want callmanager to overwrite the CDR flat files.
Till I get the billing server, I want to offload CDR flat files and store it somewhere.
Mudassir
06-23-2009 07:30 AM
You don't necessarily need an actual billing server, this sends the files via FTP to a server.
The other option is to do this via CLI one file at a time... and you still need an FTP server where to send the files.
java
06-23-2009 07:39 AM
I was looking for something like we did in Callmanager 4.x.
Create a DOS bat file and copy all the files from CDR directory to a FTP server.
Is there a procedure like this for Callmanager 6.x.
Copying one file at a time is painfull.
Mudassir
06-23-2009 07:46 AM
Yes, that's why the option is the billing server which send this automatically.
You cannot install or create any scripts on the server, maybe run the script somewhere else and send the instructions by ssh session. I'm not a programmer so i'm not even sure if it's possible.
java
