Error Fax
Jun 23rd, 2009
i have some problemx with a fax, incoming fax in error, i get just some part of the fax and i had an error.
I have configured them with CCA 2.0 analog port fxs 0/0 is in mode "FAX" signal "loop start" extension "301"
Some fax are good and other are incomplete, what can i do?
Marcos Hernandez Tue, 06/23/2009 - 08:16
  • Blue, 1500 points or more
What is the PSTN connection? Is it  a SIP trunk?
Marcos
Marcos Hernandez Tue, 06/23/2009 - 08:29
Please attach a "show run". Don't forget to hide the passwords/
Marcos
Marcos Hernandez Tue, 06/23/2009 - 08:45
Please try the following configuration
voice service pots
  fax rate voice
Let me know if that helps,
Marcos
Marcos Hernandez Tue, 06/23/2009 - 08:48
Tenet to the UC500 (192.168.10.1), login and then enter configuration mode by typing "conf t". Enter the commands I gave you earlier and then type "exit". Finally save your config with "write mem".
Marcos
