frame relay
Jun 23rd, 2009
I am trying to set a frame relay lab so I can create the cloud and proceed with my BCSI exam training. I have
2 x 2610 with 2 serial interfaces
1 x 2510 w/ 2 serial interfaces
2 x 2900 XL switches
Please help
Overall Rating: 0 (11 ratings)
Giuseppe Larosa Tue, 06/23/2009 - 11:24
  • Hall of Fame,
    Founding Member
Hello ocporbust,
I would look for a 2500 with more serial interfaces to be used as FR switch. This would allow you to have three FR DTE routers and to emulate all the terrible NBMA issues with EIGRP, OSPF and RIP.
To be noted that you can use A/S interfaces with the only limit that when used in sync mode they cannot go faster then 128 kbps: it is enough to configure accordingly the other sides.
For each connection you need a V.35 DTE and a V.35 DCE cable or the equivalent composite cable.
for FR switching see
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_cfg_frm_rly_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1055601
Hope to help
Giuseppe
cisco steps Tue, 06/23/2009 - 12:32
Giuseppe Thanks for the link, is there anyway you can help with the physical setup..
I have 3 router each w/ 2 serial interfaces, I have 3 DCE/DTE cables.
where so I start as far as cabling.
cisco steps Tue, 06/23/2009 - 12:43
here is what I did so far. I connected
r1--s0---DCE to r2--s0--DTE
r1--S1---DCE to r3--s1--DTE
is this how its suppose too
Giuseppe Larosa Tue, 06/23/2009 - 20:47
  • Hall of Fame,
    Founding Member
Hello Octorbust,
the setup is correct.
You need to configure the clock rate command on the side where the DCE cable is connected.
you can check this with
sh controller ser x/y
it will say DTE cable detected or DCE cable detected.
To be noted that OSI L1 DCE and FR L2 DCE can be on the two different sides but for clarity it is usually DCE cable on the FR switch side.
Hope to help
Giuseppe
cisco steps Thu, 06/25/2009 - 07:54
Thanks Giuseppe ,
what I need now is to configure the router to create the cloud,
I spent 2 days trying to create but no success. Can you help or provide a config example to do that
.. Gracias
cisco steps Thu, 06/25/2009 - 11:14
still no go, here is my config based on the link provided.
R3#sho run
Building configuration...
Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname R3
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
encapsulation frame-relay
no fair-queue
clockrate 64000
interface Serial0.1 point-to-point
ip address 10.23.23.3 255.255.255.0
frame-relay interface-dlci 232
interface Serial1
no ip address
no keepalive
shutdown
clockrate 64000
interface Serial1.1 point-to-point
ip address 10.33.13.3 255.255.255.0
frame-relay interface-dlci 131
line con 0
line aux 0
transport input all
line vty 0 4
login
end
R2#sho run
Current configuration : 682 bytes
version 12.3
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface Ethernet0/0
no ip address
shutdown
half-duplex
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
interface Serial0/1.1 point-to-point
ip address 10.23.23.2 255.255.255.0
ip http server
no ip http secure-server
ip classless
line con 0
line aux 0
line vty 0 4
end
R1#sho run
Current configuration : 720 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
memory-size iomem 15
no aaa new-model
ip subnet-zero
ip cef
no ip address
shutdown
half-duplex
interface Serial0/0
no ip address
no keepalive
interface Serial0/0.1 point-to-point
ip address 10.13.13.1 255.255.255.0
interface Serial0/1
no ip address
shutdown
no ip http server
ip classless
line con 0
line aux 0
line vty 0 4
end
cisco steps Thu, 06/25/2009 - 12:01
more info:
3#sho ip int b
Ethernet0 unassigned YES not set administratively down down
Serial0 unassigned YES not set up down
Serial0.1 10.23.23.3 YES manual down down
Serial1 unassigned YES not set up up
Serial1.1 10.33.13.3 YES manual up up
cisco steps Thu, 06/25/2009 - 12:42
here is also some more info that may make a since...
R1#sho frame-relay pvc 131
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
DLCI = 131, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial0/0.1
input pkts 0 output pkts 70 in bytes 0
out bytes 23870 dropped pkts 0 in pkts dropped 0
out pkts dropped 0 out bytes dropped 0
in FECN pkts 0 in BECN pkts 0 out FECN pkts 0
out BECN pkts 0 in DE pkts 0 out DE pkts 0
out bcast pkts 70 out bcast bytes 23870
pvc create time 01:36:26, last time pvc status changed 01:07:18
R2#sho frame-relay pvc 232
DLCI = 232, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial0/0.1
input pkts 0 output pkts 23 in bytes 0
out bytes 6658 dropped pkts 0 in pkts dropped 0
out bcast pkts 18 out bcast bytes 6138
pvc create time 00:17:56, last time pvc status changed 00:16:00
R2#sho frame-relay map
Serial0/0.1 (up): point-to-point dlci, dlci 232(0xE8,0x3880), broadcast
R2#sho frame-relay lmi
R1#sho frame-relay map
Serial0/0.1 (up): point-to-point dlci, dlci 131(0x83,0x2030), broadcast
cisco steps Thu, 06/25/2009 - 12:47
I made some changes ,, and if you look @ my troubleshooting .. I was able to get all the interfaces UP/UP , the only thing that I suspect is that both PVC STATUS= STATIC.. per my notes one should be STATIC and the other should be ACTIVE..
Thanks and I hope this is not too much of the info.
Edison Ortiz Thu, 06/25/2009 - 18:25
  • Hall of Fame,
    Founding Member
it seems that you want R3 to be the FR Switch, do the following config changes:
erase the entire config on R3 and enter the following:
frame-relay switching
int s0
description R1
clockrate 64000
no shut
frame-relay intf-type dce
frame-relay route 131 interface Serial1 232
int s1
description R2
clockrate 64000
no shut
frame-relay route 232 interface Serial0 131
On R2
no ip address 10.23.23.2 255.255.255.0
ip address 10.13.13.2 255.255.255.0
cisco steps Fri, 06/26/2009 - 07:14
Edison ,
something is still wrong.. there is no communication , I have up /up on all interfaces...
R2
interface Serial0/0
no ip address
no keepalive
R3
interface Serial0
description R1
no ip address
no fair-queue
clockrate 64000
interface Serial1
description R2
no ip address
clockrate 64000
R1
interface Serial0/0
no ip address
no keepalive
cisco steps Fri, 06/26/2009 - 08:00
R3(config)#frame-relay switching
R3(config)#
R3(config)#int s0
R3(config-if)#description R1
R3(config-if)#clockrate 64000
R3(config-if)#no shut
R3(config-if)#frame-relay intf-type dce
%Serial0 :Frame Relay not configured on interface
R3(config-if)#frame-relay route 131 interface Serial1 232
I get this error !!!!!!!
Giuseppe Larosa Fri, 06/26/2009 - 09:48
  • Hall of Fame,
    Founding Member
Hello Octoirbust,
do
conf t
frame-rel switching
int ser0
enc frame-relay
Hope to help
Giuseppe
cisco steps Fri, 06/26/2009 - 11:26
Giuseppe ,
I changed my config so many times that I am lost right now.
can you pls help w/ full config for r1 , r2 and r3 ..can do it anymore.. I just get more confuse.
cisco steps Fri, 06/26/2009 - 14:59
here is my current config
r1
interface Serial0/0
ip address 192.168.10.5 255.255.255.252
no keepalive
serial restart-delay 0
frame-relay interface-dlci 103
r3
interface Serial0
ip address 192.168.10.6 255.255.255.252
no keepalive
no fair-queue
r2
interface Serial0/0
ip address 192.168.10.10 255.255.255.252
no keepalive
fair-queue
frame-relay interface-dlci 203
r3
interface Serial1
ip address 192.168.10.9 255.255.255.252
no keepalive
Edison Ortiz Fri, 06/26/2009 - 15:43
  • Hall of Fame,
    Founding Member
I forgot to include encapsulation frame-relay in my previous post, my apologies - I was doing the commands from the top of my head.
Can you please go back to that config and include that command as well on R3?
It should work and R3 will become your FR Switch device.
jimmysands73_2 Fri, 06/26/2009 - 18:03
  • Silver, 250 points or more
Using R3 as the FR Switch, and not being too sure of what the author was actually trying to do, here are my working configs below. From R1 I can ping R3 and vica versa. I used Cisco NetLabs for this fyi, so I couldnt change the cables, hence the DCE config on the FR switch and the clockrate on the R2 sw. And my ports changed alittle bit. I forgot one thing, why from R1 can I not ping R1? Would I need a fr map statement?
R1#ping 10.13.13.2
Sending 5, 100-byte ICMP Echos to 10.13.13.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/56 ms
R1#sh run
Current configuration : 933 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Serial0/1
interface Ethernet1/0
no ip address
shutdown
half-duplex
ip forward-protocol nd
no ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
R2#ping 10.13.13.1
Sending 5, 100-byte ICMP Echos to 10.13.13.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/60 ms
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface Serial0/1
clock rate 64000
no ip address
shutdown
half-duplex
ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
R3 configs in next post, this one too long.
R3#sh frame-relay rou
Input Intf Input Dlci Output Intf Output Dlci Status
Serial0/0 131 Serial0/1 232 active
Serial0/1 232 Serial0/0 131 active
R3#sh run
Current configuration : 1227 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
description R1
no ip address
no fair-queue
clock rate 64000
frame-relay route 131 interface Serial0/1 232
interface Serial0/1
description R2
no ip address
no fair-queue
frame-relay route 232 interface Serial0/0 131
no ip address
shutdown
half-duplex
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
transport input all
line vty 0 4
login
end
R3#
Edison Ortiz Fri, 06/26/2009 - 20:23
  • Hall of Fame,
    Founding Member
In order to ping the serial interface of R1 from R1, you need a frame-relay map statement pointing to the remote DLCI or you can use subinterfaces.
When pinging the local serial, the packet actually tries to exit the interface and since there isn't any mapping for that IP, it fails.
HTH,
__
Edison.
cisco steps Mon, 06/29/2009 - 10:07
ok , Thank you all for your help. got the frame-relay up and running,
