ASA syslog
Answered Question
Jun 23rd, 2009
Why does the firewall block the following IPs? 207.105.ttt.ttt is the outside int. of the firewall. Below the syslog mssgs is the firewall's "access-list OUTSIDE-ACL".
06-23-2009 09:33:38 Local4.Warning 192.168.1.10 Jun 23 2009 09:06:52: %ASA-4-106023: Deny udp src outside:77.67.10.132/3478 dst Inside:207.105.ttt.ttt/51458 by access-group "OUTSIDE-ACL" [0x0, 0x0]
06-23-2009 09:33:29 Local4.Warning 192.168.ooo.ooo Jun 23 2009 09:06:43: %ASA-4-106023: Deny tcp src outside:78.153.19.185/2427 dst outside:207.105.ttt.ttt/445 by access-group "OUTSIDE-ACL" [0x0, 0x0]
access-list OUTSIDE-ACL extended permit udp any host 207.105.ttt.ttt eq syslog
access-list OUTSIDE-ACL extended permit icmp any any echo
access-list OUTSIDE-ACL extended permit icmp any any echo-reply
access-list OUTSIDE-ACL extended permit icmp any any unreachable
access-list OUTSIDE-ACL extended permit icmp any any time-exceeded
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.xxx eq smtp
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.xxx eq ssh
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.xxx eq https
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.xxx eq www
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.xxx eq pop3
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.yyy
access-list OUTSIDE-ACL extended deny tcp host 60.223.nnn.ttt any
access-list OUTSIDE-ACL extended deny tcp host 89.0.fff.eee any
access-list OUTSIDE-ACL remark "IPS ALERT ACCESS TO BARACUDA"
access-list OUTSIDE-ACL extended permit tcp any host 207.105.ttt.yyy eq https
Correct Answer by Collin Clark about 7 years 11 months ago
You will need to set the logging level to Informational (6).
Overall Rating: 5 (1 ratings)
Collin Clark Tue, 06/23/2009 - 12:16
  • Purple, 4500 points or more
It blocks it because there is no rule to permit it. The only rule with 207.105.ttt.ttt is the following-
Anything other than syslog will be denied.
saidfrh Tue, 06/23/2009 - 12:32
Since this is a stateful firewall, does access to the firewall from outside that was not initiated from the inside produce a syslog message?
Correct Answer
Collin Clark Tue, 06/23/2009 - 12:34
