Load Balancing and HSRP running simultaneously in 3750
Jun 23rd, 2009
In my topology i have four servers with two 3750 switch.Two servers are connected to Switch-A and another two servers are connected to Switch-B.Now i want achieve loadbalancing between switches like both in Active-Active(50%-50% load sharing) and when one switch goes down another switch must took the full responsibility and continues it operations.
I guess load balancing can be achieved using Etherchannel grouping and that failover responsibility can be done using HSRP since it is L3 switch.
Can i able to achieve this?
Is HSRP and Etherchannel grouping can be done simulatneously.???
Hari
Collin Clark Tue, 06/23/2009 - 12:10
Etherchannel and HSRP would only work if a switch went down, not the host. For host redundancy you can use NIC teaming on the server. You will still need to load balance some how. I would suggest looking at the Cisco ACE.
Hope that helps.
harisivaji Tue, 06/23/2009 - 12:28
Yes for Host redundancy NIC teaming is provided and also we are planning for ACE but i need switch level load sharing first then when one goes down other should take responsibility.I guess it will work i want to know any hidden problem is there or not because i have no experience in this.
Hari
