Router Error Codes
Answered Question
Jun 23rd, 2009
Can anybody explain me the meaning of the Router error Codes"499,65" or is there any Document from which i can refer, Then please let me know.
Correct Answer by joesnyde about 7 years 7 months ago
Can you tell us what version of ICM this is?
You should be able to navigate to c:\icm\bin and find the icrmess.hlp file. Open this file and select look up error, then enter the error number and from the drop down select call router. You will see information regarding both 499 and 65.
Make a shortcut for the help file on the desktop for easier access.
Overall Rating: 4.5 (2 ratings)
jason.mcdonald Tue, 06/23/2009 - 14:17
Mitesh,
You can refer to either the ICM master help, or the Database Schema Documentation for your ICM version. One of those two documents (depending on where you are seeing the errors you mention) should have your answer.
Jason
mitesh.mishra Fri, 06/26/2009 - 06:35
Jason,
I checked all those documents and also from Cisco Websites but i didnt get any results for error codes.
Correct Answer
joesnyde Fri, 06/26/2009 - 06:46
david.macias Fri, 06/26/2009 - 10:13
Thanks Joe for reminding me of that, it has been a while since I had seen it.
david
