telnet and ssh configurations
Answered Question
Jun 23rd, 2009
  • Bronze, 100 points or more
Hi every body!
My book shows the following configuration:
line vty 0 15
login
password cisco
Book says " The 'line vty 0 15' configuration command tells the switch
that commands that follows apply to to all 16 possible concurrent virtual terminal connections to the switch,which includes telnet as well as SSH access"
My understanding is , given the above config, ssh access is not possible as ssh access requires atleast username and password be confgured . So basically the above config is only valid for telnet. But the excerpt from the book, quoted above,says ( the last line) the above config apply to both telnet and ssh.
Please consider the following config:
2) line vty 0 15
login local
transport input telnet ssh
username sarah password cisco
crypto key generate rsa
my question is if i have to telnet to this switch, will i be prompted for username and password? or i will be prompted for username and password only if i connect via ssh?
thanks a lot!
Correct Answer by Edison Ortiz about 7 years 10 months ago
Your books seems outdated, the default used to be 'all', now it's none.
http://www.cisco.com/en/US/docs/ios/termserv/command/reference/tsv_s1.html#wp1022885
HTH,
__
Edison.
Correct Answer by thotsaphon about 7 years 10 months ago
Zeeshan,
In case of your configuration above. Yes you need to define a user for login local. However,"username sarah password cisco" will be used as privilege level 1.
HTH,
Toshi
Yes, you've changed the login protocol from line password to login local authentication so all input connections to the vty will use the local username|password combination, not just telnet but also ssh.
HTH,
__
Edison.
While the SSH Client prompts for an username and password for authentication, on Cisco IOS SSH server when using line password, it will accept any username (it doesn't have to be configured in the box) and the password must be the line password.
HTH,
Edit:
Current configuration : 1268 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname CE2
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default line enable
enable secret 5 $1$9.3m$khtj/6egNw9qoOksHisHU0
ip subnet-zero
ip cef
ip domain-name CISCO.COM
interface Loopback0
ip address 10.1.2.1 255.255.255.255
no clns route-cache
interface FastEthernet0/0
no ip address
duplex half
no clns route-cache
interface FastEthernet1/0
ip address 192.168.2.1 255.255.255.0
duplex full
speed auto
no clns route-cache
interface FastEthernet1/1
ip address 172.16.32.2 255.255.255.0
duplex auto
speed auto
no clns route-cache
router eigrp 10
passive-interface FastEthernet1/1
network 0.0.0.0
no auto-summary
ip classless
no ip http server
control-plane
dial-peer cor custom
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
transport input ssh
end
__________________
connecting from remote router:
CE1#ssh -l sara 172.16.32.2
Password:
CE2>en
Password:
CE2#
__
Edison.
Correct Answer by davy.timmermans about 7 years 10 months ago
for the first question:
Authentication through the line password is not possible with SSH.
It will work for sure when the login/password is overriden by AAA :
aaa new-model
aaa authentication login default local xxx
instead of local could also be group radius/tacacs used.
for the second question:
yes you'll be prompted for a username and password
Overall Rating: 5 (5 ratings)
Correct Answer
davy.timmermans Tue, 06/23/2009 - 11:23
  • Silver, 250 points or more
aaa new-model
sarahr202 Tue, 06/23/2009 - 14:54
Do you mean , even i when telnet, i will be prompted for user name and password ?
thanks a lot!
Correct Answer
Edison Ortiz Tue, 06/23/2009 - 12:24
  • Hall of Fame,
    Founding Member
HTH,
Edit:
version 12.2
hostname CE2
boot-start-marker
boot-end-marker
aaa new-model
ip subnet-zero
ip cef
interface Loopback0
no clns route-cache
no ip address
duplex half
no clns route-cache
duplex full
speed auto
no clns route-cache
duplex auto
speed auto
no clns route-cache
router eigrp 10
network 0.0.0.0
no auto-summary
ip classless
no ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
transport input ssh
end
__________________
Password:
CE2>en
Password:
CE2#
__
Edison.
glen.grant Tue, 06/23/2009 - 14:06
  • Purple, 4500 points or more
Edison is correct it will use a normal line password if say a tacacs or radius server is unavailable , we have this all over our enterprise .
sarahr202 Wed, 06/24/2009 - 09:01
Hi Edison!
Just got one more question if you don't mind.
line vty 0 15
login local
Will the above config require username sarah and password cisco from telnet user ?
Thanks a lot!
Correct Answer
Edison Ortiz Wed, 06/24/2009 - 09:04
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
Correct Answer
thotsaphon Wed, 06/24/2009 - 09:15
  • Gold, 750 points or more
Zeeshan,
HTH,
Toshi
sarahr202 Wed, 06/24/2009 - 10:22
thanks Edison.
"Yes, you've changed the login protocol from line password to login local authentication so all input connections to the vty will use the local username|password combination, not just telnet but also ssh."
According to my book, transport input telnet is on by default. That also means only telnet connection will be allowed and telnet users will be prompted for username and passwords. To allow ssh connection, we must configure " transport input telnet ssh".
Am i correct?
thanks a lot and have a nice day!
HTH,
Edison Ortiz Fri, 06/26/2009 - 07:51
  • Hall of Fame,
    Founding Member
Sarah,
I want to correct my previous statement.
That section of the documentation needs to be updated. It does mention in the 'Usage Guidelines' that the default 'none' applies to TTY connections but there is no mention of VTY connections.
I did a little digging and it seems the VTY connections default is set to 'all' but the documentation makes no mention of it.
