OSPF priority issue
Jun 23rd, 2009
hello,
we have a 3662 router connected to both ATM Network and IP network using OSPF. the ATM network is considered the next-hop for the all ospf routes. my need is to force the routing through Ip Network using always OSPF.
Giuseppe Larosa Tue, 06/23/2009 - 11:28
  • Hall of Fame,
    Founding Member
Hello Driss,
on the atm interface you can use
int atm x/y
ip ospf cost 1000
note:
verify current cost of routes with
sh ip route x.x.x.x
this in simple scenario can be enough unless the links are in different OSPF areas.
Hope to help
Giuseppe
drissbenattou Tue, 06/23/2009 - 14:14
hello,
thanks for reply
i have already applied it, but does not work. i noticed both static routes from both ATM and IP ? what does it mean ?
Dennis Mink Tue, 06/23/2009 - 19:00
  • Gold, 750 points or more
can you provide us examples, preferably your routing table
