Can't broadcast more than 1 SSID
I'm running 12.3(8) JEA3 on a Cisco AIR-AP1220-IOS-UPGRD (PowerPC405GP) processor with 15138K/1236K bytes of memory.
Any way to broadcast more than 1 SSID?
AP-CIS1200 -(config-ssid)#guest-mode
Dot11Radio0: Guest-ssid already existing on ssid XXXX
• Support for Multiple BSSIDs-This feature permits a single access point to appear to the WLAN as
multiple virtual access points. It does this by assigning an access point with multiple Basic Service
Set IDs (MBSSIDs) or MAC addresses.
To determine whether a radio supports multiple basic SSIDs, enter the show controllers command
for the radio interface. The radio supports multiple basic SSIDs if the results include this line:
Number of supported simultaneous BSSID on radio_interface: 8
AP-CIS1200-(config-if)#do sh controllers
interface Dot11Radio0
Radio 350 Series, Base Address 000d.291d.d73e, BBlock version 1.59, Software version 6.00.1
Serial number: AMB072306VG
Number of supported simultaneous BSSID on Dot11Radio0: 1
Overall Rating: 5 (1 ratings)
dancampb Tue, 06/23/2009 - 11:58
Just enable mbssid under the radio interface and then you can add the command "mbssid guest-mode" under each SSID config. This will allow multiple SSID's to be broadcast from the AP.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
