VPN Client removal issue
Jun 23rd, 2009
I installed the VPN Client and could not get it to work. I removed the application and tried to install a leter version but constanytly receive an error message that the computer needs to be rebooted after the deinstallation of a previous version.
I have rebooted several times, executed the manual removal process as indicated on the websit with no success and have struggled with this now for over a month.
I REALLY need my VPN working and now at a totl lost as to what to to next. Can someone please advise me on what to do or where to look for a solution. Alternately, is there another VPN client that will work for me.
winston.rolle Sun, 06/28/2009 - 09:18
I am using Windows XP with version 4 of the client. I have tried the manual removal process with no success.
Todd Pula Mon, 06/29/2009 - 06:44
Please provide the exact version of the client that you had previously installed?
Johann Frey Tue, 07/07/2009 - 05:35
i have the same problem.
i use a XP SP3 client with a vpn client 4.0.3.C-k9. if i install the vpnclient-5.0.0290 i become the error 28005!
i try to delete all regedit entry's, but i cannot delete the legacy_cvpnd
winston.rolle Fri, 08/07/2009 - 12:45
I have provided the version number some time ago but got no response. Any ideas? HELP.
