06-23-2009 01:16 PM - edited 03-04-2019 05:13 AM
folks
i have 2 sites linked on the external interfaces by a 10Mb circuit
in each site i have a hsrp cluster which is working fine BUT when i enable the link between site A & site B i get problems and hsrp drops, comes up, drops etc
i've tied the issue down to an acl but i have a query
i want the cluster on site A to be the main cluster so i'm planning to use the standby priority and set them to
site A 120 & 115
site B 110 & 105
is this a feasible solution to ensuring that site A, while it is up, remains as the primary site
sorry if this is a bit vague but its a lot more complex involving BGP on the outside and no site to site link on the internal interfaces ( i may have to use different hsrp group for this?)
thanks to anyone taking the time to read this or who makes the effort to respond
greatly appreciated
ps - any good hsrp design guides links would also be appreciated
06-23-2009 02:23 PM
For connectivity you can use any dynamic routing protocol, not just BGP. Don't know if other are option as well. HSRP is basically a LAN technology.
HSRP on both sides if on the same media should use separate group numbers.
Thanks.
06-23-2009 02:33 PM
If all your 4 routers require to present a single redundant next-hop, one HSRP group is fine. HSRP requires the media to be a broadcast domain.
Thanks.
