unable to get to internet
Jun 23rd, 2009
Hi all. I had to create a vpn profile today on the ASA that does NOT allow split tunnel. Everything seemed to go well, but I cant get to the internet once I connect. Login is OK etc, I get the right address but it ends there. I know I forgot a stupid line somewhere I just cant figure it out.
This is the tunnel group in question (config attached (I hope))
tunnel-group rtptacvpn type remote-access
tunnel-group rtptacvpn general-attributes
address-pool newpool
authentication-server-group ehr
default-group-policy newpolicy
tunnel-group rtptacvpn ipsec-attributes
pre-shared-key *
George Thomas Tue, 06/23/2009 - 13:37
Did you specify a DNS server? Also, are you able to ping an external IP address?
mx Tue, 06/23/2009 - 14:03
Thank you for the reply, let me verify if I can ping by address...
mx Thu, 06/25/2009 - 07:47
as an update, I cannot ping anything by address. I did add dns-server value to the group policy but still no joy.
Also, I cant ping anything on the inside either. :(
