site to site VPN overlapping subnets on Cisco ASA 5540
I am looking for some advice on how to properly setup a site to site VPN when there's overlapping subnets.
i.e. if you have 172.16.x.x on both sides of the tunnel.
I have set this up before and here's my config but I'm not sure if this is the best way to do it.
access-list outboundpolicy_NAT extended permit ip 172.31.21.0 255.255.255.128 19
2.168.0.0 255.255.248.0
static (outside,inside) 192.168.0.0 172.16.0.0 netmask 255.255.248.0
static (inside,outside) 192.168.0.0 access-list outboundpolicy_NAT
On the VPN tunnel, I configured this ACL:
access-list tac-VPN-domain extended permit ip 192.168.0.0 255.255.248.0 172.16.0.0 255.255.248.0
Patrick0711 Tue, 06/23/2009 - 19:03
  • Bronze, 100 points or more
If both sides are using identical encryption domains, you'll need to:
a.) Configure Policy NAT on both ends of the tunnel
b.) Use a Public <-> Private or Public <-> Public VPN connection
c.) Change the internal subnet of one firewall.
The key thing to remember about option A it that you have to policy NAT on both sides since the subnets are identical:
Example of config on ASA:
access-list Policy_NAT extended permit ip
static (inside,outside) access-list Policy_NAT
access-list crypto_ACL extended permit ip
Also remember that the policy NAT static statement will need to be located above any other static NAT statements.
