MGCP - ISDN
Jun 23rd, 2009
I have this lab scenario
Router A has a phone with DN 1002 registered to CCM7 and is also a MGCP gateway. The MGCP gateway is configured with inbound 4 significant digits.
Router A config:
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
ccm-manager switchback immediate
ccm-manager redundant-host 10.10.210.10
ccm-manager mgcp
mgcp
mgcp call-agent 10.10.210.11 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp fax t38 ecm
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
PSTN Router config:
ephone-dn 1 octo-line
number 911
label Emergency........911-999
description PSTN Phone
ephone-dn 3
number 6178632683 no-reg primary
label test +1-617-863-2683
dial-peer voice 102 pots
destination-pattern 6178631...
port 0/3/1:23 <------ back to back connection to Router A
forward-digits 10
I can call the PSTN ephone DN 6178632683 from Router A's DN 1002.
So, I presume the ISDN is working one way ,at least.
However, calling DN 1002 from the PSTN by dialing '6178631002' produces a reorder tone and the ISDN error message:
Unallocated/unassigned number
Debug shows that there is a match with the dial peer :
Translation patterns are working and there is also a route pattern of 617863.XXXX - PreDot
I am not sure what is wrong, any help appreciated.
Paul
PSTN# debug isdn q931
Jun 24 00:48:21.551: ISDN Se0/3/1:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 911
Jun 24 00:48:21.551: ISDN Se0/3/1:23 Q931: Sending SETUP callref = 0x0095 callID = 0x8016 switch = primary-ni interface = Network
Jun 24 00:48:21.551: ISDN Se0/3/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0095
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '911'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '6178631002'
Plan:ISDN, Type:National
Jun 24 00:48:21.571: ISDN Se0/3/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8095
Jun 24 00:48:21.575: ISDN Se0/3/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8095
Cause i = 0x8081 - Unallocated/unassigned number
Jun 24 00:48:21.579: ISDN Se0/3/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x0095
Jun 24 00:48:21.587: ISDN Se0/3/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8095
Jaime Valencia Tue, 06/23/2009 - 21:05
  • Cisco Employee,
  • Hall of Fame,
    2011
You set the significant digits, but what about the inbound CSS? can it reach the phone?
java
if this helps, please rate
PAUL CHEN Tue, 06/23/2009 - 21:35
There are no CSS configured in CCM .
Is CSS needed at all ?
