Error opening NVRAM on Cisco 3550
Jun 23rd, 2009
On a Cisco 3550 IOS switch. When I run the show configuration command, I get "error opening nvram" Or the device hangs. Show run works ok. What could be causing that problem?
smothuku Tue, 06/23/2009 - 21:59
  • Silver, 250 points or more
Hi ,
Checkout below options...
1. Enable 'service compress-config' to compress the configuration before 'write memory'.
This compressed config will take less nvram space, due to which nvram geometry will be
initialized correctly.
2.
a.) erase the nvram by write erase
b.) unconfigure some configs to fit the configs into nvram.
c.) Issue write memory
Repeat steps a, b, c until this error message vanish.
3. On platforms that support it, "boot config ..." can be used to save the
configuration to another file system other than nvram.
4. If the router has already been reloaded "write erase" should reinitialise
nvram and allow "write memory".
Cheers :) MSK
glen.grant Wed, 06/24/2009 - 03:55
  • Purple, 4500 points or more
Do a "dir flash" and see how much space you have left there , you may be out of space and need to delete items like unneeded images etc..
