Facing problem in MLA parameter configuration on Cisco Call Mananger 4.1
Jun 23rd, 2009
Hi!
I want to configure read only access for my client in the Call Manager.
Now to do this we have to enable MLA parameter. But in the Cisco TAC case collection it shows that there are issues when MLA is enabled .
Kindly reefr the links mentioned below.
1. http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K13072010
2. http://www.cisco.com/warp/public/707/cisco-sa-20060118-ccmpe.shtml
So do let me know the solution on this.
Rob Huffman Wed, 06/24/2009 - 05:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rajesh,
For the reference the in TAC Case collection, the "work-around" is nicely shown, so this should not be an issue.
For the vulnerability issue in the second doc, you need to make sure that you are at one of the "fixed-in" versions;
4.1
4.1(2)ES55 4.1(3)ES32
4.1(3)SR2 or later
Hope this helps!
Rob
