Help regarding SSH
Jun 23rd, 2009
Hi all,
i have one 3750 switch ,with ios :ipbase-mz .when i have configure ssh they not support ,i think we have to change ios to ipbasek9-mz .can 3750 support that ? also pls suggest regarding ssh commands .
mayankparekh13 Tue, 06/23/2009 - 23:35
thanks kishan ,
for these doc ,but one question is that the crypto generated rsa is stored where ? or we have to change crypto authentication but why ?
davy.timmermans Tue, 06/23/2009 - 23:38
to support SSH, you need indeed a K9 image.
username zzzz secret yyyy
ip domain-name a
hostname b
this will be used for creating the keys b.a
creating the keys:
crypto key generate rsa general-keys modulus
it's also possible to work without domain name via label parameter in the crypto key command
"crypto key generate rsa general-keys label LABEL modulus xxx" I think
modulus has to be at least 768 in order to support SSH2.
By default you will enable SSH v1 and SSH v2
eventually you can change this to SSH2 only (show ip ssh will display 1.99 as version):
ip ssh version 2
line vty 0 15
login local
A modulus of at least 1024 is recommended.
mayankparekh13 Wed, 06/24/2009 - 00:53
Thanks davy,
can i upgrade c3750-ipbase-mz.122-44. to c3750-ipbasek9-mz.122-44.
? or latest version ,
glen.grant Wed, 06/24/2009 - 03:50
Yes you can upgrade to crypto version as long as you stay with the same ipbase feature set and you have a CCO account to download the images.
