G.729 IVR prompts on ISR
Jun 23rd, 2009
hi, all!
Did anybody recorded *.au prompts for ISR with G.729 payload?
I got a pretty headache trying to find the way to record or convert existing prompts to G.729...
Help will be very appreciated, thanks!
2 votes
Paolo Bevilacqua Wed, 06/24/2009 - 03:03
Hi, already replied in another thread.
Cisco recommends "cooledit". Other SW may do as well.
ilyaavers Wed, 06/24/2009 - 21:25
no results.
neither "cooledit" nor "sound forge" has no capability to save G.729 encoded files.
maximum result achieved - i have clean G729 encoded bitstreams created by asterisk's converter or using tools from here: http://www.voiceage.com/openinit_g729.php
These files has no AU headers thus no playable by IOS.
Two another variants: use this http://www.ciscounitytools.com/HelpFiles/SetWAVFormat.htm tool, which requires Unity on windows (I have no Unity) ot to use built-in to CCM4 MOH transcoder (I have no CCM4).
may your recorder.tcl be used for this with incoming call thru g729 dial-peer?
thanks for your help.
Paolo Bevilacqua Wed, 06/24/2009 - 23:47
At least for cooledit, that incorrect. As I wrote in a previous post, the conversion is not done with "save as", instead you've so select all the stream, then hit F11 that activates the actual recoding. You see a progress window and it takes a little time.
If you changed the header format to g.728 in recorder.tcl, it should record a g.729 call as so, but I never tried that.
ilyaavers Thu, 06/25/2009 - 01:19
Sorry, I cannot find the way to save 729 from cooledit...
Maybe vesrion? I have 2.1.
F11 button only allows resampling but not recoding to 729.
ilyaavers Sun, 06/28/2009 - 22:33
Finally i got the result using au_convert.exe utility from Cisco TAC.
This is the only way to do this as I see.
echaubet Wed, 05/22/2013 - 08:58
Is there any chance to find the au_converter.exe on the CCO or on internet?
Thank you for your help.
