7942 not supported on CCM 5.0.4 ???
Jun 24th, 2009
I just got a 7942 ip phone (first time) on my CCM 5.0.4 . downloaded Devpack for 5.0.4 and installed and it didnot give me an option for 7942.then i tried to install 7942 cog.sgn ...cmterm-7942_7962-sccp.8-4-4.cop.sgn ...and it tells me to check the Md5 hash ..all of those firwares in the cisoc download are from 0ct 2007 there is not update ....any suggestions ........
Overall Rating: 0 (2 ratings)
davygu3dtgnt Sun, 01/30/2011 - 01:54
hi,
I have the same problem , who can help me ? after packet, try to upgrade with cop.sgn....but always tell me "MD5 hash against to cisco ......
3dtgnt_ljm Sun, 01/30/2011 - 23:45
Hi Java,
I want know whitch step I lost, after upgrade 5.0.4 packet, I restart ccm and tftp service , even restarted ccm server , but I cannot find any "7942" in Device Default , and when I want join 7942 to system by MAC address, but I cannot find 7942 model in the list. What can I do after upgrade ?
bvanturn Mon, 01/31/2011 - 02:23
7942 is not supported on cucm 5.0(4), a minimum of 5.1(1) with device pack cmterm-devicepack5.1.1.3125-1 (or higher) is needed.
Upgrading from 5.0(4) would be a good idea regardless. A direct upgrade is possible to 5.1(3f) available from the download section (you may need to log in into cisco.com for the link to work).
3dtgnt_ljm Tue, 02/01/2011 - 06:49
Dear Bvanturn,
Thank you very very much !  It spend me 3 days to find the truth, you give me a clearly answer, thank you again.
