help enabling ssh
Answered Question
Jun 24th, 2009
I have one 2811 router configurated with ssh enabled and I need to configure another one. The IOS version of the one configurated is 12.4(13b) and the other one is 12.4(9)T7.
I've read the documentation to enable ssh, but this router I have doesn't have
'ip domain-name' nor 'crypto key' configured, but you can connect it via shh and I wonder if there is a way to configure it without crypto key.
The configuration of line vty is:
line vty 0 4
exec-timeout 60 0
privilege level 15
password 7 09595A0439161213
login local
transport input telnet ssh
Thanks and regards
Correct Answer by davy.timmermans about 7 years 9 months ago
ip domain-name is used for the creation of the SSH keys
hostname.domainname
maybe afterwards the domain name has been removed or the key is generated with a 'label' parameter. With the label, hostname.domainname is not used for the creation of keys
Overall Rating: 5 (1 ratings)
davy.timmermans Wed, 06/24/2009 - 01:08
  • Silver, 250 points or more
probably a key has been generated:
show crypto key mypubkey rsa
the generated key is most of the time not in the config.
usuario0001 Wed, 06/24/2009 - 01:21
you are right, I can see the crypto with that command.
And what about the 'ip domain-name', do I have to configure it, because in the router it isn't configurated:
no ip domain lookup
Thanks and regards
Correct Answer
davy.timmermans Wed, 06/24/2009 - 01:36
hostname.domainname
