Cisco works assistant 1.1 with LMS 3.1
Jun 24th, 2009
Setting a default credentials in ciscoworks assistant is compulsary before discovering devices in LMS 3.1.
For example primary username & password & enable password. OR
In common services if i dont select any protocol in discovery module and any seed device except snmp settings will LMS would be able to discover???
Thnaks
Joe Clarke Wed, 06/24/2009 - 09:03
Setting up default credentials is NOT required. You can simply configure some SNMP credentials in Discovery directly or through CWA, then Discovery will work.
ciscoowsc Wed, 06/24/2009 - 13:11
Then for what purpose the primary credentials & secondary credentials & enable secret is used for.
while discovering some of the devices are unreacheable but actually they are reacheable from ur previous archives i have seen discovery issues that u have mentioned that cheked with SNMP for reacheability,by doing SNMPwalk or packet capture
Can i do a snmpwalk from my LMS 3.1 portal or advice me for any third party software for snmpwalk.
Joe Clarke Thu, 06/25/2009 - 08:46
The other credentials are used for other applications. For example, the username and password credentials are used by RME to fetch and deploy device configurations and software images. The read-write community string is used by applications such as RME, Campus, and IPM.
You can do an SNMP Walk from Device Center.
