Voice mail greetings
Jun 24th, 2009
is there a way to disable users from recording voicemail greeting?
I am using Cisco Unity Connection version: 2.0.1.2000-337
We don't want users to be able to personalize greetings. we only want users to use system default greetings only.
mwuest Mon, 06/29/2009 - 05:08
Hello
I have the same Problem, do you have a Solution for this problem?
emmanuel.shoroma Mon, 06/29/2009 - 05:49
not yet. the problem is that though you can disable the alternate greetings, the users can still activate them as the conversation give them the option. this is a worrying factor because the conversations which comes with Unity connection can't be changed or modified.
Is there any expert who can help us here? i think the solution can be there if the setup options on conversations can be disabled.
