M (not the James bond 007)
Jun 24th, 2009
How do you like it?
Do you think it should log "tcp connection information"?
At least I'd like to see statistics related to directory harvesting.
(yes, I am aware of the tool - spamtowho).
Chris
mychrislo_ironport Fri, 06/26/2009 - 10:35
I have a wishlist
- ability to track custom X-header (or is it already working using custom log subscriptions????)
- ability to save search query/critieria
- ability to run the saved query to generate pdf and send out the report
- ability to search more than 1000 results.
mychrislo_ironport Sat, 06/27/2009 - 09:44
the list goes on
- have "not" option in the search criteria, i.e. not in, not contain etc.
- have top 10/20/50 of most received subjects.
