DSL Router IOS VPN Problem
Answered Question
Jun 24th, 2009
Hello, I'm trying to configure a LAN to LAN VPN with an 870 router. It's running 12.4 IOS with the correct 'k' feature set. First of all I configured the router to work on the DSL line without VPN - this worked fine. I then added the VPN configuration and it now doesn't work at all. The configuration looks OK to me:
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.2
ip dhcp pool mypool
network 10.10.10.0 255.255.255.0
dns-server 194.72.0.114
default-router 10.10.10.1
lease 0 2
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 2
crypto isakmp key cisco123 address 172.16.134.194
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set vpn esp-aes 256 esp-md5-hmac
crypto map vpn 10 ipsec-isakmp
set peer 172.16.134.194
set transform-set vpn
match address 110
archive
log config
hidekeys
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
interface ATM0.1 point-to-point
pvc 0/38
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
hold-queue 100 out
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name redback
ppp authentication chap pap callin
ppp chap hostname xxxxxxx
ppp chap password xxxxxxx
ppp pap sent-username xxxxxxx password xxxxxxx
ppp ipcp dns request
ppp ipcp wins request
crypto map vpn
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat pool mypool 10.10.10.2 10.10.10.2 netmask 255.255.255.0
ip nat inside source route-map nonat pool mypool overload
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
access-list 110 permit ip host 10.10.10.2 172.16.0.0 0.0.255.255
access-list 120 deny ip host 10.10.10.2 172.16.0.0 0.0.255.255
access-list 120 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 120
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 102 in
exec-timeout 120 0
password 7 104308010C
login
length 0
transport preferred telnet
transport input all
transport output all
scheduler max-task-time 5000
end
I just need traffic from the client on 10.10.10.2 to use the VPN to get to 172.16.0.0/16.
Any help much appreciated, thanks!
Correct Answer by r.banez about 7 years 11 months ago
Try to remove the following:
And replace it with:
ip nat inside source route-map nonat interface dialer1 overload
and return the crypto map to the dialer interface
Overall Rating: 5 (1 ratings)
John Blakley Wed, 06/24/2009 - 11:59
  • Purple, 4500 points or more
It does look okay. If you remove the crypto map from the dialer interface, do things start to work again? What's not working exactly? No internet? Internet, but no tunnels?
HTH,
John
robward Wed, 06/24/2009 - 13:45
Thanks for the reply.
I've not tried removing the crypto map. I'll have ago first thing in the morning.
The symptoms are really bizarre. No tunnel and no Internet. The tunnell does establish when I try a connection from the peer network but I can't get any data across. The peer is a VPN 3000 concentrator if that makes any difference.
Also when I try to connect to the Internet with a client PC the Router seems to hang and management sessions over the network fail. The client PC also complained of a duplicate IP address problem when it was the only client device on the LAN.
robward Thu, 06/25/2009 - 02:31
I've tried removing the crypto map from the dialer interface and it made no difference.
Correct Answer
r.banez Fri, 06/26/2009 - 18:50
robward Mon, 06/29/2009 - 04:38
Thanks that's done the trick, it's all working now!
