Nesting Macros
Jun 24th, 2009
  • Gold, 750 points or more
Is there a way to call interface level macros from global macros on the 3560 series switches (12.2.44.SE1)?
I have a defined interface level macro that I would like to be able to call from a global macro and apply to a range of interfaces.
Yes, I know that I could easily just apply it from the int range command without a global macro, but this way, I could pre-define the range without worrying that I am affecting a port that requires a different config.
