WLC 526 Corrupted image
Jun 24th, 2009
Hi;
I searched the portal but could not find the solution about my problem which is WLC 526's corrupted image. Available commands :
rub> help
blocklist FILE boot
bootp [--with-configfile] cat FILE
chainloader [--force] FILE color NORMAL [HIGHLIGHT]
configfile FILE dhcp
displayapm displaymem
find FILENAME geometry DRIVE [CYLINDER HEAD SECTOR [
halt [--no-apm] help [--all] [PATTERN ...]
hide PARTITION ifconfig [--address=IP] [--gateway=IP]
initrd FILE [ARG ...] kernel [--no-mem-option] [--type=TYPE]
makeactive map TO_DRIVE FROM_DRIVE
md5crypt module FILE [ARG ...]
modulenounzip FILE [ARG ...] pager [FLAG]
partnew PART TYPE START LEN parttype PART TYPE
rarp reboot
root [DEVICE [HDBIAS]] rootnoverify [DEVICE [HDBIAS]]
serial [--unit=UNIT] [--port=PORT] [-- setkey [TO_KEY FROM_KEY]
setup [--prefix=DIR] [--stage2=STAGE2_ terminal [--dumb] [--no-echo] [--no-ed
terminfo [--name=NAME --cursor-address testvbe MODE
tftpserver IPADDR unhide PARTITION
uppermem KBYTES vbeprobe [MODE]
grub> initrd FILE
Error 19: Linux kernel must be loaded before initrd
grub>
How can I recover WLC' s image?
Leo Laohoo Wed, 06/24/2009 - 16:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Actually, you can't. Contact TAC and have your WLC replaced.
dennischolmes Thu, 06/25/2009 - 04:34
  • Gold, 750 points or more
Attempt connecting via cli and breaking the boot process. You should have the ability to boot to the backup image on the controller. That is, if it has one.
