Cisco 5020 MTU
Jun 24th, 2009
I would like to set the MTU on all the eth interfaces to 4000. I don't think this can be done per port by simply doing MTU 4000. I believe I have to set up a policy and class map to do this now then apply that map to an individual interface. I need assistance with this. i need something simple to just set the mtu size. not worried about bandwidth, priority or the like. i want this applied to both incoming and outgoing traffic.
Overall Rating: 5 (1 ratings)
nate-miller Wed, 06/24/2009 - 09:30
  • Bronze, 100 points or more
policy-map 4k-frames
class class-default
mtu 4000
system qos
service-policy 4k-frames
end
That will do it.
The policy map is matching class-default traffic (everything by default) and giving it a 4K mtu. You're applying it to the entire system.
