Unity Connections Voicemailes sent in email?
mx
Hi. Is it possible to log in to unity connections as a user and retrieve voice mails and email them? (wav or mp3 or whatever format?)
Yes, Unity Connection has all of the functionality of Unity, without the Microsoft dependancies (or interconnections, depending on your point of view). Users can access VM from any IMAP client (including Outlook) and read, forward, and delete from there. Users can also browse to a 'webmail' style interface that allows they to do the same from a browser.
I don't know if Unity Connection has UM and VM licensing. (I think it does.) But al long as the license allows it, you can definitely get VM via e-mail in Unity Connection.
Justin Brenton
Level 4
Level 4
Hi mx,
Hope all is well.
Here is the guide on Coniguring IMAP Settings based on Unity Connection 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag175.html
Hope this Helps
Justin
Thank you both very much. Very helpful!
