CUCM Informix PKID Matching
Jun 24th, 2009
Is there any "run sql" queries that can be run on CUCM 5.x/6.x/7.x servers to correlate a PKID to a phone/translation pattern/etc description.
The reason, I ask is because the "Cisco Role Based security" logs all log a pkid/name. I want to know how to correlate that pkid to something actual pattern or Phone.
Example:
gatewayH323Save: pkid/name 1a8bb71b-7575-1494-0ef6-9d5a58f0aae8
Overall Rating: 3 (1 ratings)
Aaron Harrison Wed, 06/24/2009 - 09:57
  • Community Spotlight Award,
    Member's Choice, May 2015
You can retrieve the info like so:
run sql select * from h323device where pkid = '1a8bb71b-7575-1494-0ef6-9d5a58f0aae8'
If your device is another type, it may be in another table.
Good bets would be 'device' for phones and so on, or 'mgcp' for mgcp gateways.
Aaron
Please rate helpful posts....
Christopher Dozier Wed, 06/24/2009 - 10:14
OK, so that give this output:
admin:run sql select * from h323device where pkid = '1a8bb71b-7575-1494-0ef6-9d5a58f0aae8'
pkid fkdevice calleriddn tkcallingpartyselection tkpresentationbit fkdevice_gatekeeper displayie numdigits prefix sigdigits runh225doneverynodeflag tknumberingplan_called tknumberingplan_calling tkpriofnumber_calling tkpriofnumber_called acceptinboundrdnis numberie tkterminal zone technologyprefix endpointaddress1 endpointaddress2 endpointaddress3 signalingport useclientconfiguration activecap enableoutboundfaststart enableinboundfaststart tkmediapayload e164 pathreplacementsupport tktunneledprotocol
admin:run sql ?
Syntax:
run sql sql_statement
sql_statement mandatory the sql command to run
admin:
So my next question is, how do i get the name or ip address? Is there a way to know the possible "from" values as you said (device, mgcp, etc).
